buysell Posted May 25, 2010 Share #1 Posted May 25, 2010 I've looked the world over, OK I only googled for it,:classic: and I am unable to locate a new transverse link. I have de-rusted mine using the electrolytic method, and the removal of rust has revealed some small pin holes and very thin metal along the edges. Also much of the angle brace in the center has rotted away.Question is, what have you all done? I don't trust this critical suspension piece in it's condition.This is for my 74 260z.Thanks,Justin Link to comment https://www.classiczcars.com/topic/36000-rear-transverse-link/ Share on other sites More sharing options...
Arne Posted May 25, 2010 Share #2 Posted May 25, 2010 Looks like it is still available from Nissan, to me. The original part number was 55460-E8300, later superseded by 55460-N4700. Both Courtesy and NissanParts.cc show the later number, at around $55. Link to comment https://www.classiczcars.com/topic/36000-rear-transverse-link/#findComment-320753 Share on other sites More sharing options...
buysell Posted May 26, 2010 Author Share #3 Posted May 26, 2010 Thanks for the reply Arne.Update: I called Courtesy and NissanParts.cc and both said that the transverse link and the bushing mount brackets are discontinued. The parts are listed on their site but must have recently been discontinued. Anyone with any nos transverse link and lower bushing brackets? - Thanks, Justin Link to comment https://www.classiczcars.com/topic/36000-rear-transverse-link/#findComment-320850 Share on other sites More sharing options...
spitz17 Posted May 26, 2010 Share #4 Posted May 26, 2010 zbarn.com is your best friend... not sure if NOS ones are still available :\ Link to comment https://www.classiczcars.com/topic/36000-rear-transverse-link/#findComment-320851 Share on other sites More sharing options...
mlc240z Posted May 26, 2010 Share #5 Posted May 26, 2010 Roger at Zbarn http://www.zbarn.com/ should be able to fix you up.spitz, you beat me to it. Link to comment https://www.classiczcars.com/topic/36000-rear-transverse-link/#findComment-320852 Share on other sites More sharing options...
