I opened up the wiper motor since it wasn’t working and I found that the 3 brushes were broken, I could find the exact replacement, however I got 3 very similar and I just file them (not sure about this word but is what the translator came out with), and it seem to be working now, however when I put the high speed for the motor is even slower. I check all the connection and they are all right, does the length of the brushes have something to do with it? I ask this because it was the only measure that I didn't have a reference, and another question, and this was fault because I didn't label everything. I tried to reassemble the Arms but I can't remember how they go, I found the wiper arms diagram, but I am having trouble with the parts that attach to the motor, here are some pics, can anybody tell the order they go into, I figure it out some of them but I'm having problems with the spring,
Hope anyone can help me
TIA
https://www.classiczcars.com/topic/36033-wiper-arms/
Gil:
If you still have the linkages out of the car, then do yourself a favor... disassemble the PIVOTS (# 7 and 8) in the diagram.
The shaft holder has a pocket for grease, which over time has petrified and makes it very hard for the shaft to turn in the holder. If the body of the pivot doesn't rotate freely around the shaft, it's gunked up.
I'll do some research on the spring.
En Español para que no tengas que usar el traductor:
(Si todavia tienes el motor y los brazos fuera del carro, haste un favor, desarma los pivotes de los limpiadores (#7 y 8) en el diagrama.
Esos pivotes tienen una area dentro para grasa, que despues de tiempo se ha petrificado y hace que sea dificil para el eje del limpiador que gire. Si el cuerpo del pivote no gira libremente, esta lleno de grasa mala.
Vere si encuentro algo para el resorte.)
E
https://www.classiczcars.com/topic/36033-wiper-arms/#findComment-321094
  • Who's Online   2 Members, 0 Anonymous, 1,330 Guests (See full list)
