Order this one its the same and they supply the gaskets to nissan anyway. Loads cheaper. Correct fire ring thickness and passage placement. Dont waste the money going to nissan to buy this gasket.
http://www.thepartsbin.com/catalog/?N=9285&uts=true&Ntt=W0133-1632596&x=14&y=13
That shows a gasket for a 280ZX, but does not mention a turbo. Are the gasket different between an N/A and a turbo engine? It is also curious that they show a different part number for an '81-'82 and an '83. I thought all 81-83's were the same.
there is no difference from turbo to regular gasket. Look at part number there the same. Trust me when you order one from nissan its gonna say ishino on it. have run 20 psi threw these via to4e there fine. Still blow out the side under detonation and cost half the price.
i happen to have a turbo nissan gasket here oem from nissan and a ishino. will take a pic for yah and mic the thickness. The oem from courtesy says ishino on package. This topic is discussed in great length on hybrid. Ishino looks the same as msa gasket too for what its worth.
Up to you though. I did lots of research before i chose mine.
Edited by yetterben
  • Who's Online   0 Members, 0 Anonymous, 1,425 Guests (See full list)
