katcarl1 Posted June 10, 2010 Share #1 Posted June 10, 2010 need some help i am putting new wheel clyinders on both back wheels also new brake lines from classic tubes.i have two pieces of brake line that i think go from the wheel clyinder to the top bracket connecting with the stainless steel flex line,but cannot figure out how it goes on or maybe the line are bent wrong.please help with pictures. thanks carl h Link to comment https://www.classiczcars.com/topic/36148-back-brakes/ Share on other sites More sharing options...
Casey_z Posted June 11, 2010 Share #2 Posted June 11, 2010 CarlI rebuilt the back brakes on my 72.There are 2 different wheel cylinders.The earlier one (roughly June 72 and before) only differs from the later one(after June 72) by the angle and position the brake line attaches to the back of the wheel cylinder.Otherwise the wheel cylinders are interchangable.I used wheel cylinders for a later model than my own. It was built May 72.I went to the neighbourhood(sorry Canadian spelling eh;)) auto supply and bought a couple of brake lines and bent them myself with a $10.00 line bender.Good luck.Casey Link to comment https://www.classiczcars.com/topic/36148-back-brakes/#findComment-322236 Share on other sites More sharing options...
