Why can't I get my evap tank installed?
Been battling it for almost 2 hours and actually dented the rear quarter from the inside. It is a small dent from pushing too hard and I am pretty sure my paintless dent guy can get it out.
I cannot get it to seat in far enough to install the screws. Unfortunately I lost all my pictures from when I removed it so I have no reference.:stupid:
I have an early series 1 california car and want to keep it original.
Any help would be very appreciated.
Thank in advance.
John
Happy Fathers Day (where applicable)
HLS30-02614 has no evap tank...it came that way from factory (or so I was told, never removed the panel). Are you sure your supposed to have one?
http://www.classiczcars.com/forums/showthread.php?t=32826&highlight=evaporator+tank&page=2
Edited by motorman7
HLS30-01590 had the evap tank. I think that most US 240Zs had the evap tanks by then, especially ones sold in California. I have heard of a couple of later VINs that were originally delivered to Hawaii that didn't have them though.
John,
You do have the early plastic tank and not the later metal one, correct? I removed and replaced the later metal one on my 72 when I changed the hoses without any problems and i don't recall any tricks. Can you post a picture or two?
-Mike
I believe that a 70 would have a plastic tank.
I agree that is should have the plastic tank, but I was just trying to confirm that is what he is trying to reinstall, not the later metal tank. I believe the metal tanks are a little larger, which is why the bump out in the right side plastic interior panel is also larger.
Here is a picture of a stock plastic tank installed I found in an old thread, if that helps.
-Mike
i have the metal rank.
Sounds like you need the plastic one then. I don't think they used the metal tanks until sometime in 1971, maybe when the series II came out. I think I have a couple of the plastic tanks around here some where.
-Mike
-Mike
The 4/71 car I parted had a plastic tank. My 7/71 is metal. I think they changed to metal in 6/71.
  • Who's Online   1 Member, 0 Anonymous, 1,240 Guests (See full list)
