June 25, 201015 yr comment_323696 Nasty idea, don't even know if it's mechanically possible but.......a crack or hole internally in the engine which is allowing coolant to bypass the thermostat? Allowing constant flow of coolant even with a closed thermo? Link to comment https://www.classiczcars.com/forums/topic/36289-engine-doesnt-get-hot/?&page=2#findComment-323696 Share on other sites More sharing options...
June 26, 201015 yr comment_323709 How old is your water pump? I've seen old ones where the vanes have eroded away from not using proper engine coolant and the water pump dies a slow death. Remember it's the coolant that carries the heat away from the head and block to the radiator and a faulty pump might be the problem. Link to comment https://www.classiczcars.com/forums/topic/36289-engine-doesnt-get-hot/?&page=2#findComment-323709 Share on other sites More sharing options...
June 26, 201015 yr comment_323710 Nasty idea, don't even know if it's mechanically possible but.......a crack or hole internally in the engine which is allowing coolant to bypass the thermostat? Allowing constant flow of coolant even with a closed thermo?FYI, not all the coolant goes directly through the thermostat in some models of Datsuns. In later models, Nissan put in a bypass line from the thermostat housing to the inlet side of the front cover just before the water pump. This setup was designed to lower the pressure of the coolant in the block so that excessive pressure wasn't forced through the engine before the thermostat cracked open. An example is pulling straight onto the freeway, accelerating up to speed, using revs to do so and with the engine cold and thermostat still closed. Link to comment https://www.classiczcars.com/forums/topic/36289-engine-doesnt-get-hot/?&page=2#findComment-323710 Share on other sites More sharing options...
June 26, 201015 yr comment_323719 Oz makes a good point i pulled my pump during my rebuild and saw the steel veins where being eaten away. Since have switched to the ld28 cast pump. Link to comment https://www.classiczcars.com/forums/topic/36289-engine-doesnt-get-hot/?&page=2#findComment-323719 Share on other sites More sharing options...
June 26, 201015 yr Author comment_323733 all better, it was 2 faulty thermostats, 1 from MSA, 1 from O'reily's, went to autozone today and bought a 192 degree thermo, put it in and let her idle for a bit, thermostat reads straight up and down, i got a gun and the bottom of the thermo housing reads 180 at running tempthanks for everyones help, don't buy cheap ishon to the next thing to fix on the old girlFrankie Link to comment https://www.classiczcars.com/forums/topic/36289-engine-doesnt-get-hot/?&page=2#findComment-323733 Share on other sites More sharing options...
June 26, 201015 yr comment_323754 How old is your water pump? I've seen old ones where the vanes have eroded away from not using proper engine coolant and the water pump dies a slow death. Remember it's the coolant that carries the heat away from the head and block to the radiator and a faulty pump might be the problem.Oz makes a good point i pulled my pump during my rebuild and saw the steel veins where being eaten away. Since have switched to the ld28 cast pump.Wouldn't the eroded vanes result in an engine OVER-heating and not UNDER heating which is what his original (now resolved) complaint was?2¢E Link to comment https://www.classiczcars.com/forums/topic/36289-engine-doesnt-get-hot/?&page=2#findComment-323754 Share on other sites More sharing options...
June 26, 201015 yr comment_323755 Wouldn't the eroded vanes result in an engine OVER-heating and not UNDER heating which is what his original (now resolved) complaint was?2¢EGlad the problem is solved.When I read Oz's post I took it to mean, it would cause the engine to run hotter with damaged vanes in the water pump but because the coolant wouldn't be circulating, the coolant could possibly be trapped, not moving and much cooler at the temp sensor, thus giving the lower temperature reading at the gauge, when in reality, the engine is running hot. I thought to myself... hmmn, that could be a possibility. Edited June 26, 201015 yr by geezer Link to comment https://www.classiczcars.com/forums/topic/36289-engine-doesnt-get-hot/?&page=2#findComment-323755 Share on other sites More sharing options...
