I had my door panels re-covered with a foam backing. Problem is the window crank now drags on the new material. Eventually the window crank will scratch the material.
Is there a window crank that will fit and provide some clearence between the crank and the panel?
Thanks
Miles
https://www.classiczcars.com/topic/36348-window-crank-swap-72-240z/
I had that issue with a different car. We used that "Protective Plastic" that you peel and stick to the front part of a hood and front area. It's clear, adhesive backed and when cut in the 6" or so diameter and stuck to the door panel, it don't look half bad. And it protects the vinyl.
Just a thought.
Dave
  • Who's Online   0 Members, 0 Anonymous, 1,476 Guests (See full list)
