Ronald Posted July 1, 2010 Share #1 Posted July 1, 2010 Hi,I need a replacement right side under dash duct for my 240Z ac. Several months ago I noticed a complete set of under dash ducts for a Z but did not know that I needed them at that time. I have been looking for a month but have not found anything. Is there a generic after market product that will work?Thanks,Ron Link to comment https://www.classiczcars.com/topic/36354-under-dash-acheating-ducts/ Share on other sites More sharing options...
EScanlon Posted July 1, 2010 Share #2 Posted July 1, 2010 Ron:You'll need to be more specific. Are you referring to the A/C ducting? (i.e. you have the evaporator housing in the passenger foot well.)ORAre you referring to the vent/heater ducting that goes to the "eye-ball" vents and / or the defroster openings?E Link to comment https://www.classiczcars.com/topic/36354-under-dash-acheating-ducts/#findComment-324234 Share on other sites More sharing options...
260zCaliCar Posted July 1, 2010 Share #3 Posted July 1, 2010 If your referring to the ducting that goes to the eye-ball vents, it's still available (for my 260 at least) through Nissan. I bought both sides about 8 months ago from nissanparts.ccPrior to going to Nissan, I searched for an alternative also and couldn't find a good one. Link to comment https://www.classiczcars.com/topic/36354-under-dash-acheating-ducts/#findComment-324238 Share on other sites More sharing options...
draztik280 Posted July 1, 2010 Share #4 Posted July 1, 2010 mcmastercarr is your friend.. i ordered mine, got it the next day. thicker more durable. Link to comment https://www.classiczcars.com/topic/36354-under-dash-acheating-ducts/#findComment-324248 Share on other sites More sharing options...
cbudvet Posted July 1, 2010 Share #5 Posted July 1, 2010 Draztik280,Are you referring to the black, corrugated ducting material from the heater/ventilation system or some kind of tubing for an A/C system? I love Mcmastercarr. I plan on getting rubber to replace/remake the rubber insulation mounts for the brake/fuel lines.carl Link to comment https://www.classiczcars.com/topic/36354-under-dash-acheating-ducts/#findComment-324254 Share on other sites More sharing options...
Ronald Posted July 5, 2010 Author Share #6 Posted July 5, 2010 Ron:You'll need to be more specific. Are you referring to the A/C ducting? (i.e. you have the evaporator housing in the passenger foot well.)ORAre you referring to the vent/heater ducting that goes to the "eye-ball" vents and / or the defroster openings?EThis is the ducting that goes to the eyeball vents and defroster. Link to comment https://www.classiczcars.com/topic/36354-under-dash-acheating-ducts/#findComment-324499 Share on other sites More sharing options...
Ronald Posted July 5, 2010 Author Share #7 Posted July 5, 2010 If your referring to the ducting that goes to the eye-ball vents, it's still available (for my 260 at least) through Nissan. I bought both sides about 8 months ago from nissanparts.ccPrior to going to Nissan, I searched for an alternative also and couldn't find a good one.This is the ducting that goes to the eyeball vents and defroster. I tried Nissan and was told that they no longer carry it. Link to comment https://www.classiczcars.com/topic/36354-under-dash-acheating-ducts/#findComment-324500 Share on other sites More sharing options...
Ronald Posted July 5, 2010 Author Share #8 Posted July 5, 2010 mcmastercarr is your friend.. i ordered mine, got it the next day. thicker more durable.I Googled mcmastercarr and got a lot of hits, but nothing specific about car parts. I am looking for the ducting to the eyeball vents and defroster. If this is what you purchased can you give me more info on how to purchase the same thing?Thanks, Ron Link to comment https://www.classiczcars.com/topic/36354-under-dash-acheating-ducts/#findComment-324501 Share on other sites More sharing options...
Ronald Posted July 5, 2010 Author Share #9 Posted July 5, 2010 Draztik280,Are you referring to the black, corrugated ducting material from the heater/ventilation system or some kind of tubing for an A/C system? I love Mcmastercarr. I plan on getting rubber to replace/remake the rubber insulation mounts for the brake/fuel lines.carlI need the ducting for the eyeball vents and defroster. I Googled Mcmastercarr and got a lot of hits but nothing specific to car parts. Link to comment https://www.classiczcars.com/topic/36354-under-dash-acheating-ducts/#findComment-324502 Share on other sites More sharing options...
260zCaliCar Posted July 5, 2010 Share #10 Posted July 5, 2010 (edited) I need the ducting for the eyeball vents and defroster. I Googled Mcmastercarr and got a lot of hits but nothing specific to car parts.I bet you can get that part. Don't bother calling anyone, they don't want to bother looking it up. Someone should double check this.. But I believe you want part number 27168-E4400 and nissanparts.cc has it for $7.34. Just order it from them and I bet you'll get it.courtesyparts.com has it on their price list also for $8.28.Let us know if you get it!Edit: I think the defroster hose you want is 27161-E4401 and it's listed for $8.62 Edited July 5, 2010 by 260zCaliCar Link to comment https://www.classiczcars.com/topic/36354-under-dash-acheating-ducts/#findComment-324508 Share on other sites More sharing options...
cbudvet Posted July 5, 2010 Share #11 Posted July 5, 2010 You should also be able to get that from Z car source but you will be paying more. I agree with 260zcalicar, try the dealer. They are usually the best bet.carl Link to comment https://www.classiczcars.com/topic/36354-under-dash-acheating-ducts/#findComment-324513 Share on other sites More sharing options...
EScanlon Posted July 5, 2010 Share #12 Posted July 5, 2010 And you only need to answer once, without having to quote each person that responded to you. It keeps the thread from getting overloaded with duplicate text, and when you're answering the same information to each, really not needed.FWIWE Link to comment https://www.classiczcars.com/topic/36354-under-dash-acheating-ducts/#findComment-324516 Share on other sites More sharing options...
