I don't know exactly when the problem started but just recently I realized that my lights ( tail lights and interior dash lights) aren't working. Brakes and blinkers work just fine but when I go and turn the switch on for the interior lights nothing turns on. I figured it might be an inline fuse but the one that I could find was fine. All of the other fuses are fine as well. The headlights work just fine... So has anyone else had this problem before? If so help please! Thanks!
https://www.classiczcars.com/topic/36365-1972-240-lights-not-working/
If you still have the original fuse box, check the tightness of your fuse clips. Mine were so loose that I started having things (like the radio) shut off and turn back on at random intervals because the clips were rattling.
I used really small tie-wraps to squeeze the clips together, but MSA and others sell replacement fuse boxes as well.
