I'm about 1/2 finished with the first splash guard.
There was a longitudinal crack at the top of the arch. and a couple cracks at the front, where the bolt is, and near where the headlamp wire goes through.
I first tacked the crack together using GOOP, and then used a cut-up antifreeze jug to form a patch, or backing piece. The patch was heated to the softening point with a heat gun, then placed over the crack, and formed to shape with a dry rag. The patch was then glued on the back of the part so it will not be seen. The patch was oversized to provide strength to the old, thinly-made splash guard.
I will do the same with the crack at the front; you just have to move quickly to get the backing piece to form well to to the splash guard.
Since the clips for the fender arch lip are not available, I will probably use a clip for electronics, such as below.
  • 3 weeks later...
If you could get one in Polyrethane, it would be great. I bet everybody would have them on. the only problem is that no one makes those for the S30, and the only ones you can get are steel, used and probably rusted too.
thxZ
Tomo, he's a spambot from the Philippines. Note the syntax of the post and the cheezy link......
IP Check - 222.127.15.250
222.127.15.250 appears in our database 13 times.
Country of origin: Philippines
Date IP address Username Email Address
6/Aug/10 11:01 AM 222.127.15.250 armandjones82 armandjones82 @ yahoo.com
Edited by sblake01
