I am redoing my door panels and don't know how to attach the fuzzy window strip to the edge of the door panel. The original fuzzy strip was attached using several large staples. I have not been able to find any kind of stapler that I thought would work for this. My only other thought would be a heavy duty epoxy to hold it. Does anyone have any suggestions? Thanks.
carl
https://www.classiczcars.com/topic/36450-fuzzy-window-strip/
I just did my fuzzy strips from MSA and used some super weather strip adhesive instead of staples. Be sure to align the fuzzy strip to the top of the panel-not too high or too low. Pre-glue both sides and let it tack partially. Position the strip and hold in palce with clothes pins spaced about one inch apart. I let it sit for a few days before I removed the clothes pins. It works and there are no staples to scratch the glass.
Also note: completely remove any rivits or staples before you glue the fuzzy strip to the door panel or they will cause all kinds of problems installing the strip and when you install the panel on the door. I used a dremel with a cut-off wheel to remove the rivits/staples.
  • Who's Online   2 Members, 0 Anonymous, 619 Guests (See full list)
