Been tracking down a intermittant squeak & dull thumping sound from the rear for the last few weeks. Also some vibration under power (there since I got the car but seemed to be getting more pronounced)
The sound went away after the car gets up to speed, >30mph and some days seemed worse than others.
Took a look at the driveline, checked all the bolts, driveshaft as well, and found a little play in the passenger side half shaft. Pulled it yesterday & discovered alot of play in the inboard u-joint, bearings shot.
Had both joints replaced with Neapco joints at Drivelines NW (did a great job, 2 hr turnaround) and refurbed the rest of the shaft myself.
Got it back in, went for a drive and the problem is Gone!
About and 90% improvement. Very pleased, much smoother & no unusual noises.
Will pull & check the driver side shaft tomorrow for peace of mind.
Drivelines NW ... Recommended
nice glad you figured it out. u-joints are evil. they always cause weird random noises when going out. i had one that was out in a truck i bought but you couldnt tell my moving it around, it didnt make any clunking but squeaked and had a grinding noise sometimes. i got under there tried moving it around and inspecting and couldnt find a thing, a month later it broke completely i got it replaced and i never ever heard those noises again.
Wife had a Pinto (yea, I know) that would bang like hell if you slowly took off from a stop. If you floored it (whoa, the power!), not a peep. Turned out the Ujoints were shot.
Definitely different noises based on different conditions/scenarios.
I had a Pinto in the late 70s but my Pinto had a Racer Brown camshaft, twin sidedraft Delortos, head work, a light flywheel, etc. It screamed! Unfortunately it didn't hande a well as it ran as the guy that bought it from me wrapped it around a telephone pole in the hills above Pomona, Ca. and still walks with a limp to this day.....
Yea, Steven I hear you.
After we replaced EVERYTHING in the car (trans, Ujoints, distributor, etc etc) she ran pretty good and was a VERY reliable, economical car. Station wagon was very versatile since it moved us from apartment to apartment and then some. Actually liked it during the '70's oil 'crisis'.
  • Who's Online   1 Member, 0 Anonymous, 946 Guests (See full list)
