Grab a good double-handful of marbles. Count 'em. Put 'em in the tank with a good cleaning solution. Shake vigorously for three or four days. Pour out the solution and marbles. Count 'em. Use POR to seal the inside and let cure for the recommended time. You should be fine.
I will second the por-15 repair. Buy the kit and it will have everything you need. I used a piece of chain because i don't believe marbles would be abrassive enough to loosen the rust particles. It is a pain in the a$$ job but it is well worth it. The por-15 coating works well-but follow the instructions to the letter. Good luck!
  • Who's Online   2 Members, 0 Anonymous, 1,043 Guests (See full list)
