Oiluj Posted December 19, 2011 Share #25 Posted December 19, 2011 That's quite a task. Good work! Link to comment https://www.classiczcars.com/topic/36693-progress-on-rust-repairs/?page=3#findComment-374849 Share on other sites More sharing options...
240260280z Posted December 19, 2011 Share #26 Posted December 19, 2011 Looks great Dan! Link to comment https://www.classiczcars.com/topic/36693-progress-on-rust-repairs/?page=3#findComment-374853 Share on other sites More sharing options...
Z Greek Posted December 19, 2011 Share #27 Posted December 19, 2011 Wow, very nice work. I was just admiring your battery box. I was working on my battery tray area not an hour ago. I am very lucky, my car is very solid over all, but the battery tray area is really a mess. Previous owner had laid fiberglass cloth over the whole area, and then riveted the battery tray back in. I have a parts car that looks like it may be pretty solid in the battery tray area, I think I might cut pieces from it. Link to comment https://www.classiczcars.com/topic/36693-progress-on-rust-repairs/?page=3#findComment-374856 Share on other sites More sharing options...
Zealous Posted December 19, 2011 Share #28 Posted December 19, 2011 Wow this is simply amazing I wish I had your skills. Looking forward to seeing the final product. How did you treat the metal after you welded in new sections. Link to comment https://www.classiczcars.com/topic/36693-progress-on-rust-repairs/?page=3#findComment-374866 Share on other sites More sharing options...
esmit208 Posted December 19, 2011 Share #29 Posted December 19, 2011 Goin' hard at it! I LOVE IT! My 72 is just waiting for me to get a WELDER. Just keep dreaming of the day it's all finished. Link to comment https://www.classiczcars.com/topic/36693-progress-on-rust-repairs/?page=3#findComment-374888 Share on other sites More sharing options...
esmit208 Posted December 19, 2011 Share #30 Posted December 19, 2011 This is what my battery tray area looks like now. Left and righ rocker as well before sand blasting. Link to comment https://www.classiczcars.com/topic/36693-progress-on-rust-repairs/?page=3#findComment-374889 Share on other sites More sharing options...
240dkw Posted December 19, 2011 Author Share #31 Posted December 19, 2011 Zealous: I am treating everything with POR15 that I can get at after welding, I used a weldable primer on all of the peices that I can not get at after and will spray some type of coating inside the rails once I am done. Z Greek & esmit 208: Somewhere on this site I read that using a section on a old fender to replace the metal under the battery tray works well, This is what I did and the curve of the fender matches quite well. Link to comment https://www.classiczcars.com/topic/36693-progress-on-rust-repairs/?page=3#findComment-374916 Share on other sites More sharing options...
Z Greek Posted December 19, 2011 Share #32 Posted December 19, 2011 Zealous: I am treating everything with POR15 that I can get at after welding, I used a weldable primer on all of the peices that I can not get at after and will spray some type of coating inside the rails once I am done. Z Greek & esmit 208: Somewhere on this site I read that using a section on a old fender to replace the metal under the battery tray works well, This is what I did and the curve of the fender matches quite well.Thank you very much for the advice! I have searched a number of times, but did not see the post referring to using an old fender. I am surprised there are no commercially produced patch panels available for that area, since it seems at least half of all Z's suffer there. Opportunity for someone in the sheet metal business? Link to comment https://www.classiczcars.com/topic/36693-progress-on-rust-repairs/?page=3#findComment-374919 Share on other sites More sharing options...
Zealous Posted December 19, 2011 Share #33 Posted December 19, 2011 Thanks. Are you painting with POR15 and then using an etching primer for sanding and levelling? Link to comment https://www.classiczcars.com/topic/36693-progress-on-rust-repairs/?page=3#findComment-374948 Share on other sites More sharing options...
240dkw Posted December 20, 2011 Author Share #34 Posted December 20, 2011 Thanks. Are you painting with POR15 and then using an etching primer for sanding and levelling?JC: I miss read your post, I am only using the POR15 on the insides of everything. On the finished side it is the normal cleaning and leveling coat of bodyfiller with fiberglass strands followed by etching primer and final coat of filler if needed.Dan Link to comment https://www.classiczcars.com/topic/36693-progress-on-rust-repairs/?page=3#findComment-374969 Share on other sites More sharing options...
MotoManMike Posted March 5, 2012 Share #35 Posted March 5, 2012 Are you keeping track of your hours? I'd be very interested in how much time it takes you to complete. Very nice metal work too. Link to comment https://www.classiczcars.com/topic/36693-progress-on-rust-repairs/?page=3#findComment-382951 Share on other sites More sharing options...
240dkw Posted March 7, 2012 Author Share #36 Posted March 7, 2012 Sorry, no I am not tracking hours. I get side tracked a way to easy to ever mark down the time spent on the car. I will be welding and stop for a break, pick up a part and start cleaning it up for later and not get back to welding for a couple of hours. Very ADD of me but it keeps me enjoying the project. Link to comment https://www.classiczcars.com/topic/36693-progress-on-rust-repairs/?page=3#findComment-383243 Share on other sites More sharing options...
