For the rear suspension, I believe you have to change the moustache bar, longer driveshaft and reverse the diff mount. I'm pretty sure the late '72-73 is when they made this modification to eliminate the vibration from the high half-shaft angles.
I'm sure someone can correct me if my mfg dates are wrong.
Granted, John.
Just finished 'refreshing' the rear suspension (bushes, struts, springs etc) and would have done the repositioning if I had all the parts (no moustache bar).
Just figured I'd mention it if Wilson had all parts available to fix the issue. Kinda a 'While I'm at it" thing.
I actually have an extra moustache bar and diff mount (i think) from a r200 rear end z. I only bought it because I was just looking at those parts at my junkyard, took it off, and thought, well, I already did the work, might as well buy the part.
  • Who's Online   2 Members, 0 Anonymous, 1,262 Guests (See full list)
