This guy has a bunch of them and although his shipping is kind of high, the total cost is lower:
http://cgi.ebay.com/ebaymotors/Valve-Spring-Compressor-3087-_W0QQcmdZViewItemQQitemZ230482519736QQptZMotorsQ5fAutomotiveQ5fTools
The total cost is a bargain. I'm curious though, because at that price and the fact that he makes no mention of the KD Tools brand, if these are "cheap" knock-offs.
Oh well, I've been known to do business with Harbor Freight. LOL
Edited by moonpup
Auction ended with no bids??????
Diseazd, did you fall asleep or just found one somewhere else? ;)
Moonpup....I ordered the $15.00 item that SBLAKE01 offered. I was waiting to see the item before I replied. It looked liked the real deal and even a knock off would be fine for this simple task. I will get back to you as soon as I receive it. Thanks for your help. Guy
Just received my valve spring compressor from Stephen's ad above.......It is a KD 3087......High quality tool. Great price too($15.00 PLUS $10.00 shipping) received it 5 days after buy-it-now date....Thanks so much for everyone's help...you guys are awesome! Guy
Glad that worked out for you. I've had my valve spring compressor for so long I don't even remember where I got it. It's either a no name or the anything that identifies it has long since worn off. It might even be a Harbor Freight item though it looks very similar to the KD 3087.
  • 3 years later...
Not too dificult to make one of these. You need access to a small lathe.Hack saw. Drill. Some pipe for a handle, three or four inches of heavy wall tube to machine into the required dimensions to press on the valve spring, some 1/8 inch flat m/s to cut into a hook shape to go under the cam. A couple of 3/8 inch bolts. A bench grinder, and some imagination.
Edited by olzed
