laneyone Posted August 24, 2010 Share #1 Posted August 24, 2010 Well she still doesn't look like some of the restore projects I've seen on here, but she sure sounds and performs better. Changed the gasket and the valve cover gasket. With some sage advice from Dr. Steve at Steve's Motorsports, No real problems except for the heat sheild. Who put those bolts under there??!! Note the numbered tape, I call that my trail of crumbs. Link to comment https://www.classiczcars.com/topic/36880-intake-exhaust-gasket-extravaganza/ Share on other sites More sharing options...
Walter Moore Posted August 25, 2010 Share #2 Posted August 25, 2010 ...Note the numbered tape, I call that my trail of crumbs.Yep, always a good idea to mark everything possible, at least until you have taken it apart and re-assembled it so many times that you have memorized everything. Link to comment https://www.classiczcars.com/topic/36880-intake-exhaust-gasket-extravaganza/#findComment-328935 Share on other sites More sharing options...
