Hi All,
I have done some searches but i need info asap, my fuel pump is going out and i need a replacement for a triple carbed l28. I mainly need to know what is the recommended psi and GPH that i need to run effectively without regulator. With that said would a pump that puts out 4-6 psi at 32 GPH be too much for the carbs without regulator?
Thanks in advance
Edited by NismoZ
https://www.classiczcars.com/topic/37028-help-fuel-pump-choices-and-specs/
Thanks for the reply Zforce, I ended up buying a facet pump that seems to be working ok but I am question it reliability. Its psi seems to fluctuate from 5 to 2 psi. it will run at about 5 psi in the beginning then drops down to 2 after driving the car. Is this normal for electric fuel pumps?
  • Who's Online   2 Members, 0 Anonymous, 1,145 Guests (See full list)
