mbarjbar Posted September 17, 2010 Share #1 Posted September 17, 2010 I have a 1970 Z that was originally 907 Green. PDO painted it white. I am going to have the car blasted and repainted. I am torn between keeping this early car (4095) original or change to a modern color, i.e., platinum gray micas or metallic. Opinions wanted. Will it drastically devalue the car? I was leaning toward original, but every green car I see, seems to look dirty.Mike Link to comment https://www.classiczcars.com/topic/37115-color-change-v-value/ Share on other sites More sharing options...
ZCurves Posted September 17, 2010 Share #2 Posted September 17, 2010 First, It is your car, so do with it what makes you happy.If I were going to do a color change, then it would have to be complete (engine bay, interior, rear deck).Staying with the OEM color is safer and cheaper which is what I did. I have to say that a major factor that I stayed with the original color was because I just did not want to go to all of the effort to gut my Z to that level (e.g. I was lazy). I also really like the 510 Sky Blue Metallic.I did consider doing the Electric Blue from an '05 Infiniti G35, but I liked the 510 Blue better.So, 907 Green or whatever turns you on - It is your car, do with it what makes you happy. Link to comment https://www.classiczcars.com/topic/37115-color-change-v-value/#findComment-331024 Share on other sites More sharing options...
JohnnyO Posted September 17, 2010 Share #3 Posted September 17, 2010 If you are going to blast it down to metal all over as Zcurves mentions above you can choose from any of about 15 stock colors for the early series 1 cars.There is no permanent coding on the car that states the original color. Link to comment https://www.classiczcars.com/topic/37115-color-change-v-value/#findComment-331031 Share on other sites More sharing options...
pwd Posted September 17, 2010 Share #4 Posted September 17, 2010 I'm going through the same dilemma regarding color choice. My '73 was 113 Avocado Green, which is not something I'd be interested in driving around in. I'll either paint it 918 Orange (an iconic 240Z color), or 901 Silver (always a safe color), and restore it 100% original, requiring an interior color change from Butterscotch (that vinyl is NLA) to Black, or just go with a non-original color altogether, do a "sympathetic" restoration, and have fun with it.Good luck with your decision. Link to comment https://www.classiczcars.com/topic/37115-color-change-v-value/#findComment-331032 Share on other sites More sharing options...
mbarjbar Posted September 17, 2010 Author Share #5 Posted September 17, 2010 Thanks guys. When I restored my MGB, it was bronze yellow. 240s had the same color, sort of a butterscotch orange. Anyway, I went with a Mazda color call galaxy gray mica. It brought the car into the 21st century. I think my 'Z' would look good in this color too. BTW, I am ditching the butterscotch interior for black also. Link to comment https://www.classiczcars.com/topic/37115-color-change-v-value/#findComment-331035 Share on other sites More sharing options...
Gary in NJ Posted September 17, 2010 Share #6 Posted September 17, 2010 ...I've be jonesn' for an MGB... Link to comment https://www.classiczcars.com/topic/37115-color-change-v-value/#findComment-331049 Share on other sites More sharing options...
ChrisZ Posted September 17, 2010 Share #7 Posted September 17, 2010 BTW, I am ditching the butterscotch interior for black also.Can you tell me more about that interior, i'm on lookout for some butterscotch interior parts.Chris Link to comment https://www.classiczcars.com/topic/37115-color-change-v-value/#findComment-331065 Share on other sites More sharing options...
Arne Posted September 17, 2010 Share #8 Posted September 17, 2010 (edited) ...I've be jonesn' for an MGB...Been there, done that, threw away the T-shirt. A Z is a lot more fun to drive. First, It is your car, so do with it what makes you happy.I agree 100%.If I were going to do a color change, then it would have to be complete (engine bay, interior, rear deck).Staying with the OEM color is safer and cheaper which is what I did. I agree here, too. If you're going to do a color change, anything less than a complete bare-shell deal will reduce the desirability of the car to many people, and therefore its value.A non-stock color may or may not reduce the value further, depending on the rest of the car. If you are intending to keep it stock and unmodified, a non-OE color will ruin the effect, and the value will drop. But if the car is going to be modified, especially in a non-period manner, a well-done modern color is probably not too big of a detriment. Edited December 19, 2010 by Arne Link to comment https://www.classiczcars.com/topic/37115-color-change-v-value/#findComment-331067 Share on other sites More sharing options...
mbarjbar Posted September 17, 2010 Author Share #9 Posted September 17, 2010 Arne, don't be so hard on the 'B'. I have a blast with mine and I can put the top down.....Gary, 'B's are out there, just as with the 'Z', look out for rust, especially in the sills.ChrisZ, PM me regarding interior parts. Some of the plastic is good, vinyl trim is pretty good and would clean up.Mike Link to comment https://www.classiczcars.com/topic/37115-color-change-v-value/#findComment-331069 Share on other sites More sharing options...
ChrisZ Posted September 17, 2010 Share #10 Posted September 17, 2010 Mike, PM on it's way, thanks. Chris Bwt, why MGB when you can get a SPL311 ? Link to comment https://www.classiczcars.com/topic/37115-color-change-v-value/#findComment-331070 Share on other sites More sharing options...
Arne Posted September 17, 2010 Share #11 Posted September 17, 2010 (edited) Arne, don't be so hard on the 'B'. I have a blast with mine and I can put the top down.....If you enjoy it, I'm all for that. I towed home a basket case '67 (pictured above) and spent 4 years restoring it. Had a blast hunting down all manner of obscure parts for it, and rebuilding everything. I think the only bits that didn't have my fingerprints on them was the internals of the banjo diff. Drove it two more years after it was done before I admitted to myself that hunting parts and restoring it was lots more fun than just driving it. Sold it in '95 and haven't missed it a bit. Edited December 20, 2010 by Arne Link to comment https://www.classiczcars.com/topic/37115-color-change-v-value/#findComment-331072 Share on other sites More sharing options...
Graphx007 Posted December 19, 2010 Share #12 Posted December 19, 2010 I am very interested in butterscotch interiors. I have just PMed you. Any help is greatly appreciated. Link to comment https://www.classiczcars.com/topic/37115-color-change-v-value/#findComment-339228 Share on other sites More sharing options...
