Rust repair panels 78 280Z 2+2
THorsma
To start with a few check these people out..........www.fourways-engineering.co.uk, www.thezstore.com, ...........www.rustrepair.com,.............. www.thefind.com. To find others just insert "240Z REPAIR PANELS" into your search engine and it reveals plenty of suppliers. GOOD LUCK and get a good welder that uses CO2
THorsma
Thank you for the information.
I would call Charlie and ask him if the front floor pans are the same on the Coupe and 2+2 - he has the floor pans manufactured.
http://www.datsunzparts.com/NewParts/summary.htm
FWIW,
Carl B.
Thank you. Charlie says that he's not aware of any made for other than a coupe. But they can be made to work. Depending on the amount of rust to remove and additional section of metal can be spiced in.
Thank you for the info.
  • Who's Online   2 Members, 0 Anonymous, 1,376 Guests (See full list)
