In need of a Hazard light switch (1972 Z) anyone? Please!!
well my lights are acting a little funny cuz when i turn the light switch to the parking lighrs the both arrows that are in the tacho turn on and the front 2 parking lights and the left corner light are off then when i use the blinkers this 3 light that dont turn on start blinking and i already check the wiring,the bulbs and the fuse box but no luck finding a solution to this problem and i think my last resort is to find another hazard switch since i heard that they go bad and that all the cables for the lights run thru it. also one thing that i noted is that when i bought my car it came with the pull switch rather that the flip up switch (my car is a 1972) so i dont know if this switch was changed at some point or if it came like this from the dealer (I know that all the early Z's were suppoused to come with the flip up switch
Well thanks for your help in advance
The pull switch is from a 73. Electrically I believe its the same. You can take it out, dis-assemble it, clean the contacts, and re-assemble it. Do the same with the head light switch on the steering column assembly. If you don't want to tackle that, send it to Z'sondabrain for work. If you just want a new switch, put an ad on the want to buy section of the site.
I was tempted to suggest you learn about the period when composing sentences, but I finally spotted one in your text, so I won't bring that up. :)
Jim
well thanks guys!! =) i found someone that had and extra switch, I should be getting it this week and i hope that this will fix my problem, cuz if not i guess i will be here again asking for help
Thank you!!!!!!
  • Who's Online   0 Members, 0 Anonymous, 1,565 Guests (See full list)
