JGW06 Posted October 30, 2010 Share #1 Posted October 30, 2010 Any advice on removing exterior trim, weatherstripping, bumpers, emblems, to prepare for painting? I need to know correct tools, tips, etc so that I damage/ destroy as little as possible. 1983 280zx 2+2Thx Link to comment https://www.classiczcars.com/topic/37521-advice-removing-exterior-trim-wratherstripping-prior-to-paint/ Share on other sites More sharing options...
EScanlon Posted November 2, 2010 Share #2 Posted November 2, 2010 Your question is so broad that any attempts at answering it requires hours of work.While Wick Humble's book (How to restore your Datsun 240Z) may be of the prior model, much of the information contained therein will still apply to your car. If nothing else it will provide you with a basis for asking more specific questions that will hopefully give results.Your question, as it stands is more along the lines of "I'm going camping in Yellowstone Park, what should I take?" There will be tons of questions before any will offer any answers.HTHE Link to comment https://www.classiczcars.com/topic/37521-advice-removing-exterior-trim-wratherstripping-prior-to-paint/#findComment-334942 Share on other sites More sharing options...
kenz240z Posted November 2, 2010 Share #3 Posted November 2, 2010 If you have a factory service manual for your ZX, it should have information on removal/installation of the trim, emblems, bumpers, etc... Items like the bumpers will be bolted on. In general, embems & trim can be tricky because you need to determine how they are attached. Could be adhesive, retainer pins, screws or nuts. A good set of plastic pry tools is handy for popping off emblems & trim that are attached with adhesive or retainer pins. Be sure to double check for hidden screws or nuts so you don't accidently break something... Link to comment https://www.classiczcars.com/topic/37521-advice-removing-exterior-trim-wratherstripping-prior-to-paint/#findComment-334968 Share on other sites More sharing options...
JGW06 Posted November 2, 2010 Author Share #4 Posted November 2, 2010 Your question is so broad that any attempts at answering it requires hours of work.While Wick Humble's book (How to restore your Datsun 240Z) may be of the prior model, much of the information contained therein will still apply to your car. If nothing else it will provide you with a basis for asking more specific questions that will hopefully give results.Your question, as it stands is more along the lines of "I'm going camping in Yellowstone Park, what should I take?" There will be tons of questions before any will offer any answers.HTHEOk, completely understand. When someone starts in on a new hobby (or job, etc.), we don't know how much we don't know! I'll pick up the book referenced and read, then as I plan the removal, replacement, etc., I'll ask more specific questions. Thanks for your patience! Link to comment https://www.classiczcars.com/topic/37521-advice-removing-exterior-trim-wratherstripping-prior-to-paint/#findComment-334981 Share on other sites More sharing options...
