T-stone Posted November 4, 2010 Share #1 Posted November 4, 2010 I am having some issues with my 1972 240, i upgraded my cam put a header on replaced radiator, alternator and voltage regulator.I set the timing and started it got everything tuned, today when i started the car and gave it a little gas the gauges flickered and dimmed.I shut it off and started it again, after letting it idle again i raced the engine and around 5000 rpm the gauges dimmed again. while running the amp gauge fluctuates greatly. when idling the amps are consistent slightly positive, when racing the engine the amps jump to high positive and fluctuates slightly positive to high positive.also after running for a while smokes starts coming from the electricals on the steering collum, i found that the right blinker wire was unplugged.need some help Link to comment https://www.classiczcars.com/topic/37568-electrical-problems/ Share on other sites More sharing options...
SteveJ Posted November 4, 2010 Share #2 Posted November 4, 2010 Where did you get your alternator from? Are you sure it is externally regulated? Did you take voltage measurements at the battery with the car off? Link to comment https://www.classiczcars.com/topic/37568-electrical-problems/#findComment-335088 Share on other sites More sharing options...
T-stone Posted November 4, 2010 Author Share #3 Posted November 4, 2010 i bought the alternator from aurozone, it specifically said that it was external regulated. the battery has 12.4 volts when checked with a meter Link to comment https://www.classiczcars.com/topic/37568-electrical-problems/#findComment-335090 Share on other sites More sharing options...
T-stone Posted November 4, 2010 Author Share #4 Posted November 4, 2010 scratch that 12.15 Link to comment https://www.classiczcars.com/topic/37568-electrical-problems/#findComment-335091 Share on other sites More sharing options...
Travel'n Man Posted November 4, 2010 Share #5 Posted November 4, 2010 I would be extremely concerned with the voltage regulator!! Where did you get it and are all the connections secure on both the male and female side? Whats going on with your Altmeter? Is it outside the + side - off the gauge? Link to comment https://www.classiczcars.com/topic/37568-electrical-problems/#findComment-335092 Share on other sites More sharing options...
T-stone Posted November 4, 2010 Author Share #6 Posted November 4, 2010 both alternator and regulator are from autozone, connections are secure.amp gauge runs from slightly positive to past the line of high positive and jumps back and forth at high rpm Link to comment https://www.classiczcars.com/topic/37568-electrical-problems/#findComment-335095 Share on other sites More sharing options...
SteveJ Posted November 4, 2010 Share #7 Posted November 4, 2010 I just realized I had a typo in my previous post. What is the voltage at the battery with the car on?As Mitchell suggested, it looks like the voltage regulator might not be functioning properly. Link to comment https://www.classiczcars.com/topic/37568-electrical-problems/#findComment-335099 Share on other sites More sharing options...
Travel'n Man Posted November 4, 2010 Share #8 Posted November 4, 2010 Be extremely careful with your current set up and driving your car - you could be doing some serious damage to your battery and could include exploding due to exessive overcharging..........IMO. Have you tested your battery while the car is started for overcharging? If not, I would do that ASAP.......IMO You need to inspect each and every wire on both the male side and female side - you have something not making a good connection in that juction. Once you find your culprit wire you can jump it to the correct wire outside you voltage regulator to correct the connection - or figure out a way to secure the connection in the male and female plug - it sounds to me like a wire has disconnected from either of the sides of the plug to the voltage regulator. Link to comment https://www.classiczcars.com/topic/37568-electrical-problems/#findComment-335104 Share on other sites More sharing options...
T-stone Posted November 5, 2010 Author Share #9 Posted November 5, 2010 I found that the new voltage regulator connector wire is shorter than the original one, the connection was secure but had a lot of tension.it caused a bad connection, i moved the regulator closer rleaving the tension, this made for a better connection.This fixed the problemthanks for all the great advice Link to comment https://www.classiczcars.com/topic/37568-electrical-problems/#findComment-335243 Share on other sites More sharing options...
SteveJ Posted November 5, 2010 Share #10 Posted November 5, 2010 Cool. Now that you've taken care of that issue, if you live near Atlanta, come on out to the Georgia Z Club meetings. Link to comment https://www.classiczcars.com/topic/37568-electrical-problems/#findComment-335249 Share on other sites More sharing options...
T-stone Posted November 5, 2010 Author Share #11 Posted November 5, 2010 When and where are these held? Link to comment https://www.classiczcars.com/topic/37568-electrical-problems/#findComment-335261 Share on other sites More sharing options...
SteveJ Posted November 5, 2010 Share #12 Posted November 5, 2010 Thursdays at TJ's Bar & Grill on Holcomb Bridge Road. Go to the Georgia Z Club website (link in signature) for the details. Link to comment https://www.classiczcars.com/topic/37568-electrical-problems/#findComment-335266 Share on other sites More sharing options...
