TomoHawk Posted November 15, 2010 Share #1 Posted November 15, 2010 My car is getting a new set of bushings (Springs & dampers too)- Rear suspension first, then the front. When I get to the front suspension, I might even get the engine out to refresh that too. I have everything I think I will need but the strut insulators and the diff mounts. I have the mustache bar bushings. The strut insulators are back-ordered and 'might' be in stock in a few months, but I think I can get the diff mount (stock style, but urethane is OK) very soon. The question I have right now is can I hold off until Spring and do just that one then. The "good" news is that I tried the screws holding the hard lines under the car, and from all the undercoating there, the screws turned easily and so weren't rusted in solid thxZ Link to comment https://www.classiczcars.com/topic/37674-bushing-refresh-project/ Share on other sites More sharing options...
boyblunda Posted November 15, 2010 Share #2 Posted November 15, 2010 (edited) Hi TomohawkDid a suspension renovation a little while ago and was one of the most worthwhile things I did for my Zed. Just a query or two on your project. First, what sort of bushings are you looking at putting into your car? Second, given that it looks like you are going for a major refurbish in this department are sway bars a consideration for you in this effort? Finally, does this lead into a further stage of refurbishment or is this just what you feel needs doing for now.Would like to hear some more detail about what components you are intending to use.All the best with this new chapter for your Zed.RegardsDave Edited November 15, 2010 by boyblunda Spelling Link to comment https://www.classiczcars.com/topic/37674-bushing-refresh-project/#findComment-336022 Share on other sites More sharing options...
TomoHawk Posted November 15, 2010 Author Share #3 Posted November 15, 2010 Hi Dave,I already have the Energy Suspension urethane "Master Kit" of bushings for the 280Z. It has most everything but the strut insulators, the (strut bearings for the front struts) and front diff mount. Both front & rear suspensions will also be getting new coil springs & dampers.I plan on using all the urethane bushings in the kit for the rear suspension, and all but the T/C rod bushings for the front suspension. I'll get rubber bushings for the T/C rod later. I don't know if there is a stock-style urethane unit for the diff, and a stock rubber type is on back-order at most places I tried, so I will have to us the original one (maybe it's not that bad off) until I can get a new one, and install it next Spring, but I thought I could get it now while the whole rear end is out. Link to comment https://www.classiczcars.com/topic/37674-bushing-refresh-project/#findComment-336048 Share on other sites More sharing options...
cygnusx1 Posted November 15, 2010 Share #4 Posted November 15, 2010 Just a reminder...If you do go with poly T/C rod bushings, only use the forward facing bushing in poly. Use stock rubber ones on the backside of the T/C bucket. This keeps from over-stressing the T/C rod when it moves up and down with the suspension. Link to comment https://www.classiczcars.com/topic/37674-bushing-refresh-project/#findComment-336064 Share on other sites More sharing options...
TomoHawk Posted November 15, 2010 Author Share #5 Posted November 15, 2010 I"ll just use urethane and/or rubber bushings...http://www.differencebetween.net/object/difference-between-urethane-and-polyurethane/ Link to comment https://www.classiczcars.com/topic/37674-bushing-refresh-project/#findComment-336065 Share on other sites More sharing options...
cygnusx1 Posted November 16, 2010 Share #6 Posted November 16, 2010 The ES bushing kit is Polyurethane. The bushings are very stiff and can harm the T/C rod if used on both sides (front and back) of the T/C bucket. Bad things happen when the T/C rod cracks. Link to comment https://www.classiczcars.com/topic/37674-bushing-refresh-project/#findComment-336097 Share on other sites More sharing options...
Powderkeg Posted November 16, 2010 Share #7 Posted November 16, 2010 Tomohawk,There is also the option of a ball & socket Rod kit from Black Dragon pg 40 under "Performance Suspension" listed as Tension / Compression (T-C) Rod Kit.MSA also sells the same thing.I replaced my stock TC Bushings on my 76 280Z with this set-up and it works great. All of my driving is street.Dave Ruiz Link to comment https://www.classiczcars.com/topic/37674-bushing-refresh-project/#findComment-336105 Share on other sites More sharing options...
TomoHawk Posted December 26, 2010 Author Share #8 Posted December 26, 2010 I'm just going to stay with a stock-type setup for the bushings. The biggest thing that I am concerned about is that the body guys don't have to guess at how to install the replacements, because there isn't much information on that. Link to comment https://www.classiczcars.com/topic/37674-bushing-refresh-project/#findComment-339835 Share on other sites More sharing options...
cozye Posted December 26, 2010 Share #9 Posted December 26, 2010 I have the TC rod kit, I've heard that it offers a nice improvement in bump steer issues over the standard rubber bushings. I still have the poly bushings and could get some rubber ones if I want to go back. FWIW, the TC rod bushings to replace on the car would be a 20 minute job, so you can always go back.my rear strut insulators were in perfect shape. I'd start the job and see if you can get by with what you have. The front strut insulator bearings are available at the local parts store, again, mine were in perfect shape I just regreased and used the stock ones.The front differential mount is very easy to change at a later date as well. Mine was in good shape and hadn't settled at all so I re used it too. Sounds like you've got plenty of parts to start the job. I wouldn't wait for the backordered stuff. Link to comment https://www.classiczcars.com/topic/37674-bushing-refresh-project/#findComment-339850 Share on other sites More sharing options...
TomoHawk Posted December 26, 2010 Author Share #10 Posted December 26, 2010 Hi cozye, I am going to get the front insulator bearings because they are inexpensive and the local store can get them. Hopefully, from the condition of most things under the car, the strut insulators will be fine for a while, as they are $200 each and not easy to get, new. It's more likely the springs and shocks are pooped out anyway.In any case of the condition of things, I'm starting in the back and working forward, with the engine & engine bay last. Link to comment https://www.classiczcars.com/topic/37674-bushing-refresh-project/#findComment-339851 Share on other sites More sharing options...
bavarian06 Posted January 4, 2011 Share #11 Posted January 4, 2011 In terms of priority, what bushings should I swap out first? I believe I have the complete poly MSA kit and looking to get some of the bushing replaced (trying to tackle it according to importance/definite have-to-do/bang-for-the-buck-performance advantage). My local shop said they could do the complete front (steering rack included) for $200 in labor. They want $300 for the rear (including the mustache bar mounts) since the lower rear A arm bolts are a pain the butt. Is that reasonable? I was thinking of doing the fronts by myself when I install new springs/shocks. Does the front components require pressing some of the bushings in place? If that is the case, that rules out the DIY. $200 is not a whole lot of $$$ if it isnt really difficult and time consuming to do. Link to comment https://www.classiczcars.com/topic/37674-bushing-refresh-project/#findComment-340826 Share on other sites More sharing options...
TomoHawk Posted January 4, 2011 Author Share #12 Posted January 4, 2011 (edited) I am working from the back to the front, because the worn bushings are causing the tires to wear fast, and some other stuff. If you are going to to the rear bushings, you should probably also get some spindle pins, etc., because they are usually rusted in and have to be cut to be removed.For some detailed write-ups, go here: http://atlanticz.ca/zclub/techtips/suspension.htm Edited January 5, 2011 by TomoHawk Link to comment https://www.classiczcars.com/topic/37674-bushing-refresh-project/#findComment-340827 Share on other sites More sharing options...
