Okay so my 1973 240z (all smog gear removed) wont go above 60mph in 3rd or 4th gear, kind of hits a wall. Pulls strongly through RPM range in 1st and 2nd up too 5000 rpm (didn't try any higher), change to third and all acceleration ends. Doesn't seem to be hunting for extra fuel, just stays where it is.
I've checked my timing (with a strobe) it's set at 10 degrees @ 800rpm.I've tried advancing/retarding it with no improvement. I've got a new petronix ignitor (had one before replaced it as test) with new 3 ohm flamethrower coil (no ballast resistor). Just put in new NGK sparkplugs, re-checked SU float levels are correct, made sure damper oil is in dashpots, and that pistones are freely moving.
I know I've a rusty fuel tank but I cleaned rust residue out of rear pump filter, and changed front filter for testing. All to no avail. I'm guessing I have to get my tank cleaned but was just wondering if anyone had any other ideas.
Gary
https://www.classiczcars.com/topic/37806-73-240z-wont-make-it-past-60mph/
