I just got my 5 speed into my '73 yesterday-looking forward to the new ratios. Anyway, the boot that protects the slave cylinder is shot. Does anyone have a lead on where to buy these? MSA sells them-complete with the entire slave cylinder. I'd rather not spend $40.00 for a piece of rubber.
Thanks.
https://www.classiczcars.com/topic/37825-slave-cylinder-boot/
Thanks for the replies guys. I just found out that cutting 1.5" of my stick [shift] is going to run another $40.00.
From everything I've read, when you replace the slave cylinder,(even at $23.00) you are supposed to replace the master ($42.00) and the hose ($27.00) as well. So now my piece of rubber will run me $92.00+ shipping.
As a first pass I've tried siliconing the 2 broken pieces together. If I have to replace everything and bleed it out later, it's easy enough to get to.
Hoping to avoid the child support-although the Z hobby is not helping much.
  • Who's Online   1 Member, 0 Anonymous, 1,537 Guests (See full list)
