240 differential side flange spline # ?
Yes except the stamped steel shield is a different depth on the 240Z side axles. You cannot use the R160 side alxes on an R180 without cutting off that shield. The shield on the R180 side axles will sit about 3/8" away from the side seals when used in an R160.
  • Who's Online   1 Member, 0 Anonymous, 1,354 Guests (See full list)
