Oops! Points ignition! Never mind my 2nd and 3rd items!
* weak points spring?
BTW, the breaker plates are quite bad about freezing up on the 280s. I suspect the 240s are the same way. I've read that most of the ones in service won't advance. I know mine wouldn't. I replaced it with a rebuilt OEM unit -- lifetime warranted by AutoZone for $100, FAIW.
Edited by FastWoman
i took a cc brush and cleaned the distributor and i found the timing all the way retarded which im pretty sure it aint supposed to be like that, i dont where how much to advance it but i have it half way and it doesnt sputter anymore and goes pretty close to 7 grand
how much advance do you guys usually have it for stock engine?
The FSM states 5BTDC. For a stock motor I don't think you'd see much benefit from advancing that figure. I also don't think you would break anything if you had it advanced to 10BTDC.
How far did you have the timing advanced that you blew a head gasket? That had to be some serious detonation to blow the head gasket.
Adjust your timing for drivability, not horsepower. There isn't any magic horsepower hiding in the distributor.
i have it just around 5 BTDC the engine revved up nice and smooth. when i drove it around the few times revved it high a couple times but not constantly up past 6000 for more then a couple of seconds. when it did blow or crack it was late at night getting pizza with a buddy it was running fine but the water temp kept rising, i was about a minute away when the gauge was maxed out stopped there for a while to cool off the motor and wen i started it back up there was a whole bunch of white smoke. :( im thinkin that my thermostat got stuck cuz it did that to me once a while ago but i pulled over and started it back up about 30mins later and it was all fine. i got a whole bunch of gaskets n a new thermstat comming in so i can go to the hobby shop this weekend.
  • Who's Online   2 Members, 0 Anonymous, 1,042 Guests (See full list)
