blitz_86 Posted January 3, 2011 Share #1 Posted January 3, 2011 Well the rain has come and its starting to get cold,I turn on my heater and funny thing is nothing is hooked up to the switches.Now my question is where can i find the cables where i can turn on the heater thanks Link to comment https://www.classiczcars.com/topic/38124-heater-core-cables/ Share on other sites More sharing options...
ZCurves Posted January 3, 2011 Share #2 Posted January 3, 2011 Well the rain has come and its starting to get cold,I turn on my heater and funny thing is nothing is hooked up to the switches.Now my question is where can i find the cables where i can turn on the heater thanksOk, I am missing something....Is your Z missing the cables altogether? or are they just disconnected?Are there any loose cables near the selector levers on the front of the Heater Box or on the sides of the Heater Box?? If so, you can look at the FSM and reattach them. If the cables are gone, then I am sure that you can find some on this site. Make sure to list your year model.Good luck. Link to comment https://www.classiczcars.com/topic/38124-heater-core-cables/#findComment-340692 Share on other sites More sharing options...
SteveJ Posted January 3, 2011 Share #3 Posted January 3, 2011 I agree with Andrew. Look for the cables. Sometimes they will come off the clips. If you need new ones, try Zcar Source. They aren't cheap, but I've been happy with the quality of used parts I've received. They also are prompt on shipping. Link to comment https://www.classiczcars.com/topic/38124-heater-core-cables/#findComment-340694 Share on other sites More sharing options...
Zedyone_kenobi Posted January 3, 2011 Share #4 Posted January 3, 2011 This is a pic of what the cables look like behind your controls. I have to get the FSM to tell you which goes where. I forget. Link to comment https://www.classiczcars.com/topic/38124-heater-core-cables/#findComment-340697 Share on other sites More sharing options...
EScanlon Posted January 4, 2011 Share #5 Posted January 4, 2011 That picture is missing one of the cables.There are FOUR cables in a 240 Heater Control.E Link to comment https://www.classiczcars.com/topic/38124-heater-core-cables/#findComment-340718 Share on other sites More sharing options...
Walter Moore Posted January 4, 2011 Share #6 Posted January 4, 2011 That picture is missing one of the cables.There are FOUR cables in a 240 Heater Control.EYep, the one on the upper right hand corner, where the empty clamp is located.But I am sure Zedyone_kenobi was just showing the picture as a reference. Link to comment https://www.classiczcars.com/topic/38124-heater-core-cables/#findComment-340730 Share on other sites More sharing options...
JohnnyO Posted January 4, 2011 Share #7 Posted January 4, 2011 I just sold a complete setup on ebay for $10 bucks. The cable connections are pretty self explanatory. Feed them out the back of the console and attach them top right to top right connection, bottom right to bottom right connection, top left to top left connection and bottom left to bottom left connection. they are all different lengths so it is pretty easy to figure out. Get on your back on the floor boards with a flash light and a phillips for the easiest approach. Link to comment https://www.classiczcars.com/topic/38124-heater-core-cables/#findComment-340734 Share on other sites More sharing options...
bavarian06 Posted January 4, 2011 Share #8 Posted January 4, 2011 question, how do i pull out the center dash HVAC controls? i want to re-adjust my vent/heater cable and also work on my headunit. thx! Link to comment https://www.classiczcars.com/topic/38124-heater-core-cables/#findComment-340812 Share on other sites More sharing options...
JohnnyO Posted January 4, 2011 Share #9 Posted January 4, 2011 It is attached to the center console. You should download the factory service manual here: http://www.xenons30.com/reference.htmlIt will walk you through it. John Link to comment https://www.classiczcars.com/topic/38124-heater-core-cables/#findComment-340816 Share on other sites More sharing options...
Zedyone_kenobi Posted January 4, 2011 Share #10 Posted January 4, 2011 You will FIRST have to disconnect all the cables. This is beneficial since it will teach you where they are and what condition they are in. then it is a matter of taking out the light above the slider controls, and then the two screws that hold in the panel. You will have to disconnect the knob on the fan switch as well. But it is pretty straight forward.And yes, I had already removed my 4th cable now shown in the picture, but good eye! Link to comment https://www.classiczcars.com/topic/38124-heater-core-cables/#findComment-340817 Share on other sites More sharing options...
bavarian06 Posted January 7, 2011 Share #11 Posted January 7, 2011 It is attached to the center console. You should download the factory service manual here: http://www.xenons30.com/reference.htmlIt will walk you through it. JohnI looked through the manual but it doesnt specifically tell you how to remove it. I ordered the Haynes Manual so hopefully that will serve its purpose. Link to comment https://www.classiczcars.com/topic/38124-heater-core-cables/#findComment-341172 Share on other sites More sharing options...
bavarian06 Posted January 7, 2011 Share #12 Posted January 7, 2011 You will FIRST have to disconnect all the cables. This is beneficial since it will teach you where they are and what condition they are in. then it is a matter of taking out the light above the slider controls, and then the two screws that hold in the panel. You will have to disconnect the knob on the fan switch as well. But it is pretty straight forward.And yes, I had already removed my 4th cable now shown in the picture, but good eye! How do I remove the cables? Should I disconnect it from the HVAC or from the other end? I'm afraid of cracking or breaking these filmsy plastic pieces. Yesterday I made a slight tear in my lower steering column cover cause I didnt see there was one more screw buried deep inside the cover. Link to comment https://www.classiczcars.com/topic/38124-heater-core-cables/#findComment-341173 Share on other sites More sharing options...
