No shrouding needed on my Z. You don't even need the fans after 30 MPH. This new aluminum radiator cools no less than 25% more efficiantly than stock and my temp gauge rarely moves any higher than 180, if that.
Shrouds are good though. just not on my Z.
The electrics have a small shroud built in and if you mount them flush with the radiator then the air that they move will flow directly through the core.
Mechanical fans have a much larger air gap between the blades and the radiator. With this sort of setup there is more chance for air to be pulled in from the sides when the car is traveling at speeds less than 30 MPH.
I've got a little bit different eBay setup...
It is an aluminum 3 core with dual 12" fans from Monster Cooling. Each fan pulls 6 amps. I can't find the same one anymore, but here are links to a couple of similar units: eBay 3 core Radiator Link
Another eBay Link
The one I purchased fit PERFECTLY! I mounted it similar to Dave using rubber blocks and grommets. Fans are mounted with the plastic zip ties also.
I bought a thermostat control unit from Summit and it comes on at about 185 degrees.
I have not had the car on the road yet, but after running in the driveway for 30 mins, the fans kick on for a minute or so and it is right back down to 175-180. Seems to work great!
No clearance issues with the pulley at all. We'll see how it does on the road, but there is no reason to assume that it will have any issues.
I need to take a few more pics, but here are a few (old engine compartment and new)...
Tim
Actually, That's almost the exact set up I have. with the exception of 3 cores vs. my 2 core. Kicks on at 185 and drops it down to 175 very quickly.
Same fans and radiator and I'll be damned if I can find it on eBay anymore. Everyone has 3 and 4 cores now. Yet my 2 core works friggin awesome. oh well, what ever eBay thinks we need....
Beautiful engine bay Tim. What are you using for an overflow can? I went to the auto parts store and found Lawnmowerfuel line (Clear tubing) and I love it cause it shows that I have fluid and if I have air bubbles as well as if the fluid is moving either way.
If you can't find the right overflow can, try the hot rod shops.
I used 4) Chrome plated 3/8" long bolts for the water pump pulley. looks like you did too?
Looks great.
Dave
Looks great.
Dave
Thanks Dave! Yours looks amazing too! :beer: Note: Your combo switches and HLH, PLH harnesses and Diff Mount are installed. Can't wait to actually put them to use!
Here are a couple of additional "current" pics with nearly everything in place. Still need to tune everything up, but need to put in a better fuel pump first. The "replacement" RX7 pump is a POS!
I just finished the R200 and rear disc conversion and just need to tighten everything up and bleed the brakes. In the process of stripping the body now. Dash is out and gauge install is in the works.
Not sure what I will use for an overflow yet. I'll check the hot rod shops around here. Should be easy enough to find.
I have most of the "bolt on" parts for the engine and engine compartment assembled with stainless allen head bolts. Looks very clean.
I am looking at finally having this on the road in mid-late spring. I do have the LT1 and 4L60e ready to go... Decisions, decisions... LOL
Edited by SSuspect
  • 1 month later...
Sorry to revive this thread just a few quick questions. Do these radiators work with the normal fan or are they just too thick?
I also saw this great deal on an aluminium radiator and was wondering if anyone has ever bought from this place or has one of these radiators?
http://www.genesisautoparts.com/product/all35098x7107aa.htm
Has anyone purchased the MSA radiator? This is quite cheap especially with the CZCC discount and supports MSA that supports us. Is it the same as the champion type?
http://www.thezstore.com/page/TZS/PROD/PCLC04/16-6964
Just trying to do my homework before I push the buy button.
They work fine with the regular stock fan. I ran mine with the stock fan for months but went with the cool factor and better cooling Dual fan set-up. Still Plenty of clearance with the 2 core aluminum radiator.
Hit the Buy button and get that car back together.
Dave
The Thermal switch is the Probe style that goes Into the radiator via the upper hose and a small rubber wedge with a slot cut in it. THEY WORK AWESOME!!! I was able to sit in traffic for over 20 minutes, in 98 degree weather and the fans would kick on every once in a while and cooled it PDQ (Pretty Damn Quick)
The gauge never mover past the middle line due to the fans doing a great job.
Aluminum Radiator and fans $145 ?? (eBay, seller in CA.)
Thermal switch $30 (Napa in Marysville, WA.)
Some power wire, inline fuse and a relay $7 (My own stock)
2.5" x 10" Polished Aluminum overflow Can ($50 @ Dreamers Hot Rod Shop in Everett, WA.)
Total of $232 before tax. Best cooling system I ever owned.
Dave
Dave, do you remember the P/N for the thermal switch?
Nope, It was bought from NAPA and was about $30. Came with the copper line going to a 3" probe, a black rubber piece to help seal the copper line thru the rubber on the inlet. and the line is attached to a Dial Thermastat. Post #13 picture #2
I wish I wrote down the p/n. You're not the first to ask.
Similar to this.......
Also this could work....
http://www.summitracing.com/parts/DER-16720/?rtype=10
Or this......
http://www.summitracing.com/parts/DER-16769/
This one is Real close to what I have, but has a smaller dial knob and costs more.
http://www.streamlineus.com/ShowItem/125450%20Adjustable%20Temperature%20Control%20Switch.aspx
Or this one... p/n PWI30104 half way down the page.. you'll also need a relay kit for the switch to turn on the fan.
http://www.rjays.com/Cooling/elec-fans-01.htm
  • Who's Online   2 Members, 0 Anonymous, 1,437 Guests (See full list)
