Just a note to others looks like many places are out of the two row from Champion and that only the 3 rows are available at the moment. I ordered a 3 row but am concerned about the extra work the fan will have to with the air flowing through such a thick core at low speeds and when stopped. Hopefully it works out fine.
I don't think it'll be a big issue. If the stock fan is close enough and used with a shroud, it'll pull air one way or the other and cool down the contents. If you decide on Electric fans, a dual set-up will work beautifully and I almost Never hear mine unless I'm idling for at least 4 or 5 minutes without moving.
Fans draw HP away from the car and can cause premature failure of the water pump bearing, and are not even needed after 30 MPH. something to consider.
Dave
  • 10 months later...
  • Who's Online   2 Members, 0 Anonymous, 1,437 Guests (See full list)
