I am new to this form so I hope I'm doing this right,
I have recently started working on a 71 240Z with the original L24. The valves were ticking so I decided to check the clearance. when I removed the cover I imediatley noticed the oil feed tube above the cam followers was bent at the cast brace and the back section of the tube was not connected which obviousley wasen't allowing for proper lubrication of the last 2 followers. My qusetion is since the vehicle has been sitting for many years what could have caused this (possably heat)? And where can I find a part # or more importantly where can I find this part? I have already checked the local wrecking yards but no L24's to be found and the L28's didn't use this tube.
Thanks,
Eric
https://www.classiczcars.com/topic/38219-l24-oil-feed-help/
Actually, the L28s did use this tube up to late 1977, I believe, to 1976 for sure (I have one on my 1976 stock N42 head). I'm not sure when they switched to the internal oil passage cam shafts, but the N42 heads up to 1978 are worth checking.
You might be able to repair yours by brazing.
  • 3 weeks later...
I would be taking a very close look at the cam and followers for lack of oil damage. Is it poss. that a p.o. swapped in a later model drilled cam and pinched off the oil feed line? I don't know if that is even poss. but you never know. I have seen some pretty goofy p.o. stuff.
  • Who's Online   1 Member, 0 Anonymous, 635 Guests (See full list)
