Hi everyone.
I am in need of some parts to repair the rear of my 240k 4 door.
I am looking for;
Bootlid
Tailight Beaver panel
Lower box section
Any help from anyone is much appreciated.
Interestingly you can apparently still buy the tailight panel from Nissan Spare Parts for a 240k 4 door ex Japan.
Hoping for something closer, and cheaper however.
Kind Regards,
Matthew.
https://www.classiczcars.com/topic/38275-parts-required/
Hi guys, thanks for the replies.
So far I have come up with nothing, just a couple of people who have not followed through.
Mastadd240K, I will pm you about following up on your offer.
Again, if anyone has any parts, or leads on parts, it's appreciated.
Thanks.
https://www.classiczcars.com/topic/38275-parts-required/#findComment-344271
I may have a lead on some parts, about 12 months ago i spotted a sedan wreck sitting in a front yard in country S.A. I'm not sure if it is still there or for sale but might be worth a look if you have no other leads.
Let me know if your interested and i will pm you the address.
https://www.classiczcars.com/topic/38275-parts-required/#findComment-344325
Hi Guys,
Have appreciated the response thus far, and I am pleased to say I am making some inroads.
Particular thanks to Mastadd240k, and Laggy6.
Just confirming the parts I am in need of most of all, as I think my terminology was a bit off, are as follows.
This photo show the Rear Upper and Lower Box sections I need;
The upper section needs to have the welds picked and the section removed, I think the lower box section needs to be cut off, more experienced people than I will know the best way to remove these sections proffesionally.
And a BOOTLID is a must have, as mine is beyond repair.
Any help or leads are welcomed.
Thanks.
Matthew.
https://www.classiczcars.com/topic/38275-parts-required/#findComment-344632
