Correct, I might try 195 -55 -16 or 205 -45 -16 to try and sort it out. I see you also use 8" rimms, what are your front tires ?
I don't know if that would be enough if it is a 8" with 0 offset you migh need a 195/45-16. The other option is a wheel spacer. A 1/4" might do the trick. To mount Honda rims on a 240z you needed a 1/4" spacer that might fix it. Please post the specs on the rims it will help we are just putting guesses out
  • Who's Online   1 Member, 0 Anonymous, 1,354 Guests (See full list)
