Head or not to head...that is the question
I get comments on the exhaust all the time. It's either "Is that a V8?" "Dude! That sounds sweet" "ya, I heard ya coming, thought it was a muscle car or something bigger" I tell them what it is, they look surprised every time.
  • 3 months later...
I have a ceramic coated 6-into-1 squareport header, 2.5" single piece exhaust pipe, back thru a Schucks $20 Turbo muffler (Raptor Muffler)
That one is way cleaner and higher revving than mine, but here's a few samples of mine......
I wish I had a better Sound bite for ya.
here's a doughnut in the same car, about 4500 rpm???
6500 RPM's with NO Muffler
My 260Z with 6-into-1 header and 2" pipe thru a repro Ansa muffler (tip)
and Bluestreak resinator in the middle (2 feet after the header)
Dave
The Ansa muffler on your 260Z look exactly like the one on my Z, and was there in '92 when I bought it.
There will probably not be any performance difference between the stock exhaust manifold and any of the headers mentioned so far in this thread. IMHO, if you take the money you would spend on a header and spend it cleaning up the inside of the stock exhaust manifold, port matching it to the head, and getting a real ceramic coating done (not JetHot Sterling) then you'll be better off for your intended street use with a stock cam.
So John, think you can continue with the stock manifold if you go with a mild cam upgrade?
It depends on what your goals are. A mild cam upgrade will work with the stock exhaust manifold but you might get a little more with a good header. For racers that little more is well worth the effort because the car spends so much time at full throttle. For a street driven car that spends, maybe, 2% of its drive time at full throttle, its probably not worth the effort to swap out the manifold for a header.
  • 1 month later...
But just for sh*ts and giggles... who has a car that sounds like this?... AWESOME
My Rebello 3.1 stroker with triple Mikunis, 3-2-1 JetHot coated header and Ansa tip sounds just like that.... I love it!!
i think its all in what you put in your exhaust that depends on the sound. me i have a 6-1 header and 2.5 pipe and a non carb legal cat and a magna flow muffler. i have to say i get comments on the sound all the time it has a nice rumble to it and its not to ricey. im just gonna say its all in how you set it up pipe it and what you use in it i.e muffler and cat wise. just my 2 cents.
  • 2 months later...
I think whatever exhaust you decide on OTHER than stock usually manifests a drone somewhere in the rpm range. My car under load at 2000 to 2500 has a pretty loud drone noise and I try to avoid hovering in that range. I have an MSA header 3-2 with dual exhaust all the way back with glass packs AND turbo mufflers too. In hindsight I might have ran mufflers that were NOT straight thru type to help suppress noise.
On the other hand I LOVE the exhaust sound 90% of the time.
I put a long sound clip under the exhaust forum under the thread - "music to my ears", if you want to listen to the exhaust. I get a lot of nice compliments from folks who actually ride in the car, they say it sounds great.
  • 2 months later...
