Probably pretty close. You have a 70 which is lighter, but you also have R200 with LSD which adds weight. I know mine with a full carpet kit, R200 and Autopower roll bar weighed 2350 with 1/2 tank and nobody in it. I'd suspect yours is probably right around 2300. So yeah, that sounds about right.
Rebuilt 2.6 liter with a .20 bore (standard rebuild with slight bore for clean-up of the sleeves.)
Stage 2 cam (477/277)?? I think
Valve grind and some porting done
ported intake (Cleaned up to smooth it out a little (kinda standard stuff)
New Ztherapy S.U. (Installed and tuned by Steve at ZTherapy)
MSA Ceramic Coated 6-into-1 header
2.5" exhaust pipe with a Raptor Turbo Muffler
Mallory Unilite Distributor
Mallory Promaster Coil
MSD 6AL with the 7000rpm RL chip
Aluminum radiator with Dual 12" fans.
280ZX (79') 5-speed trans
R200 LSD Diff
280ZX Turbo CV's
Eagle Allow 16x7 aluminum wheels
Riken Raptor 225/50ZR16's
Eibach PR lowering springs
Tokico HP (blue) Struts
Energy Suspension (Full) Urethane kit
Interpart? T/C kit
MSA Xenon Urethane Air dam
BRE style Rear spoiler
Light weight Reclining Cushioned seats with 4-point harness
sblake01 the question was "any z vs mustang" when i was talking about my zx i was sharing one of my thoughts as an example of what i thought. i see you on the forums all the time and you are always a smart a$$.
Oh, lighten up! Didn't you see the smiley? Just giving you a hard time......
I only know that much about it cause i have build it from the ground up. If it's not stock, or doesn't look stock, it's cause I put it on or did it myself. Which is just about everything on the car.
8 years with the same car will do that to a guy
Dave
84-86 mustang svo was pretty quick. Turbo 2.3 liter PINTO engine 210 hp and with some mods good for 400 hp. Not bad for PINTO engine, Buick also had thier Grand Nat with the 87 model having 276 hp. I think if you drop the Grand Nat engine into a Z you would have a pretty demented car that would smoke a Roush, Saleen or otherwise Mustang.
Edited by Zforce
  • Who's Online   1 Member, 0 Anonymous, 1,393 Guests (See full list)
