My first question would be, who did the port work? If the answer is, "I did." I would want to know his qualifications. Did he just take a grinder to the head and call it "Race prept" and or did it go any further. i.e. Total tear down with all components properly measured and assembled. Has the Holly set up been debugged? Why is he selling it in the first place? Issues?
Why not get a good set of S.U.s for your motor and save the hassle and money. Just saying, unless that engine was professionally rebuilt, with supporting and traceable documentation I would put the money into what I already have and am familiar with.
https://www.classiczcars.com/topic/38547-efi-to-carb-swap/#findComment-345447
From what I recall in your other posts, you're having difficulty getting your car to run right as it is now. I really don't think swapping out your engine for an unknown engine with a Holley carb it the answer. About all that will accomplish would be creating a different set of problems to troubleshoot. Who would be doing the engine swap and set up?
https://www.classiczcars.com/topic/38547-efi-to-carb-swap/#findComment-345452
This is what he put
1978 datsun 280z 2.8 rebuilt engine
has the 4 barrel holley conversion
flat top pistons
a cam made by americam not shure wat lift
the head is rebuilt also and ported by l&r enginering
comes with a msa header
5 speed trans
and a centerforce racing clutch
this motor was rebuilt about 3 years ago its been sitting in my garage for 2 1/2 years already i whent with a v8 conversion
https://www.classiczcars.com/topic/38547-efi-to-carb-swap/#findComment-345457
IMO the Holley carbs are HORRIBLE. They spontaneously sprout leaks in nonserviceable areas, their micropassages are easily blocked, rebuilds are elaborate, and there is no such thing as a simple cleanout. And don't ever rip that little piece of silicone rubber on the accel pump, because it's worth literally more than its weight in gold -- just because they can. We'll be selling our Holley carb'ed boat this spring (not because of the carb), and I don't ever want to have another Holley.
https://www.classiczcars.com/topic/38547-efi-to-carb-swap/#findComment-345458
Your right sblakeo1 I have been having problems with my z lately.cause of taxes I have some money to burn,I was going to take my car down to mikeZshop in Whittier.then came across this post.I was already saving for some upgrades Before the car problems started, it's funny how when I have money problems start.I been wanting more power for the z and I guess now that it's not running right that post looked good.
Edited by anthony280z2+2
https://www.classiczcars.com/topic/38547-efi-to-carb-swap/#findComment-345462
There is an old saying to the effect that: "Nothing is as good as or as bad as it first appears".
Your engine problems need to be explored fully to find out just what is going on and even though this deal sounds perhaps brought to you through providence, it may in fact be a smoldering bag of well, you know.
https://www.classiczcars.com/topic/38547-efi-to-carb-swap/#findComment-345466
  • Who's Online   2 Members, 0 Anonymous, 266 Guests (See full list)
