Good Day Adrian
I am starting with a 280 Z shell as I believe it stronger and I have no problem with
engine and drive train. To get propper struts and springs is where I need help. Also the
propper look (fender flares, Light pods on the hood). Any help is much wanted.
Ken
Edited by Gp4VioletGTS
Good Day Adrian
Ken
Are yoe allowed to use fender flares ? and what does the regulations says ?
Suspension wise there is a lot to do for historic rally and verry profesional stuff.
Historic rallying in the US has no strick regulations. You inter your car in your National
Class and then if it is an old car you put an H after yours number plate and you are in
the Historic class. There are no Historic Stage Rallies. I can try to change this as I have
ogranized some rally sprints and rally crosses. Even if I just start off with a few cars.
I can get 6 -8 cars from just my friends. So fender flares are not a problem but I would
still like to use the right ones. Do you have any photos and specs on the suspension.
Like spring rate, travel, Strut shaft size.
Ken
  • Who's Online   1 Member, 0 Anonymous, 1,513 Guests (See full list)
