I purchased a 71 240z with an L28 block and an N42 head with a Clifford intake. I am switching back to S.U. carbs and am looking at a pair of 3 screw carbs that are available but no manifold. Can someone pls. tell me what manifold I will need to make this come together.
https://www.classiczcars.com/topic/38702-manifold-compatibility/
I was hoping you would chime in Bruce. Probably none to very little. I live on Vancouver Island, very mild and the car will be a fair weather driver only. I am looking at a set of 3 screw carbs with the float bowl drain plug. The seller is trying to find the manifolds for them.
Well, frankly any manifold will work 3 screw, 4 screw, or flat top, matters not. Flat top balance tubes are uglier than home made sin but other than that I believe the flat top manifold manifold might even flow a little better than the earlier manifolds. That is based ONLY on looking into the intake runners on both manifolds.
We are also seeing more guys wanting to disable the water thru the manifolds entirely. Just one less thing to go TU and leave one standing beside the road......
Do you know Greg McCauley on the island? He has Some Z stuff. I know he has a primo early air cleaner he'd like to sell.....
Thank you for the info.. I had visions of nightmarish parts hunting. I have owned Zs in the far, far past but then they were new and did not require a whole lot of tinkering. No, I am not acquainted with Mr. McCauley. It would be nice to be in touch with someone locally with Z interests. They are as rare as hens teeth here. ( That is rather spooky. The previous owner of the TR6 I own, was Joanna MaCauley. The TR6 had a totally B.C. history.) MMMmmm
  • Who's Online   0 Members, 0 Anonymous, 1,038 Guests (See full list)
