235/14 on 8 " rims all the way around. Steering at low speed is a bit tight, and I do get some tire rubbing at times, struts and springs will fix that, but it handels great. It's a 73 240Z.
Edited by 5thhorsemann
Okay, I am running 195/60/15's on a 15x7" panasport. I am lowered on tokiko springs and struts. When I ran 205/60/15's I rubbed on the front body work when turning, but if you have an aftermarket air dam and not the OEM body panels that should not be an issue.
I definitely noticed my car was easier to turn with the 195's on there. FYI
I'm running Bridgestone Potenza G 019 Grids, 195/60R15 on 15x7 Panosport rims.
Same wheels & tires I have on mine, which I've found to be a good street wheel/tire combination. Only difference is I've got Eibach springs which lowered the car about 3/4".
They look great both at stock height or lowered.
Dave, thanks for the compliment. The +10 offset is the wrong way for us, so to speak, but the 16x8 really helps and the +10 offset is needed for fender clearance. :)
spdcrazy, the steering is not that bad, or at least I don't think so. The tire and wheel combo are larger than stock and I had to trim the inside edge of the lower valence for clearance.
  • Who's Online   1 Member, 0 Anonymous, 1,292 Guests (See full list)
