I got my 280Z today and I wanted to fix the shift boot and shifter.
The shift knob that came with the car had lost its threading and wouldn't tighten up. So I placed in a Lexus (auto) shift knob with some minor drilling to increase the inside diameter of the knob.
Fits like a charm now and looks better than the last one did, even though this knob itself is no "looker".
I also had to fix the boot. The leather string was missing that tightens it up snuggly around the shifter. So I improvised a way to tighten it without making a run to walmart.
I used a Zip-Tie that was long enough to thread through the lip of the boot.
I actually had to get a larger one because this red zip-tie was not long enough.
I found it to be easier to push it through if you bend the tip of the zip-tie.
Force it on through and you may need either a hook or some pliers to pull it the rest of the way.
Kind of a before and after
https://www.classiczcars.com/topic/38778-sorta-diy-shift-boot-tie/
