tymarbry Posted March 18, 2011 Share #1 Posted March 18, 2011 Do Datsun Z's have clips or anything to hold the injector plugs on? I was replacing some fuel hose today and I noticed one had come off. I then realized none of the plugs have clips or anything to hold them in and it takes almost no effort to pull them off. I Elec. Taped mine. But there must be a better way? Link to comment https://www.classiczcars.com/topic/38938-injector-plug-clips/ Share on other sites More sharing options...
sblake01 Posted March 18, 2011 Share #2 Posted March 18, 2011 (edited) There are wire clips that hold the plugs on the injector. What kind of shape are your plugs in? Are they cracked/brittle? We've done a thread or two on replacing them with the 'quick release' connectors use on BMW's etc. Starting from about post # 10, read through this thread an also checkout the link in post # 10:http://www.classiczcars.com/forums/showthread.php?t=22929 Edited March 18, 2011 by sblake01 Link to comment https://www.classiczcars.com/topic/38938-injector-plug-clips/#findComment-349784 Share on other sites More sharing options...
tymarbry Posted March 18, 2011 Author Share #3 Posted March 18, 2011 Quick Release? BMW's? That sounds rad to me lets get that going.Im going to find info on that and post back hopefully! Link to comment https://www.classiczcars.com/topic/38938-injector-plug-clips/#findComment-349785 Share on other sites More sharing options...
TomoHawk Posted March 18, 2011 Share #4 Posted March 18, 2011 Use some RTV silicone stuff if you just want to keep them on temporarily,but replacing them with new ones is the only good solution. You can get good ones from the JY. I got a whole bunch from a JY called Vines Auto, where they are loaded with NMWs. Link to comment https://www.classiczcars.com/topic/38938-injector-plug-clips/#findComment-349786 Share on other sites More sharing options...
240260280z Posted March 18, 2011 Share #5 Posted March 18, 2011 Audi's also have these too. Link to comment https://www.classiczcars.com/topic/38938-injector-plug-clips/#findComment-349803 Share on other sites More sharing options...
Darrel Posted March 18, 2011 Share #6 Posted March 18, 2011 audi's, volvo's, honda's etc.Go to the junkyard with one of the old injectors plugs with you. btw, most of them are also weatherpac. Link to comment https://www.classiczcars.com/topic/38938-injector-plug-clips/#findComment-349806 Share on other sites More sharing options...
sblake01 Posted March 19, 2011 Share #7 Posted March 19, 2011 Besides the 6 for the injectors, get 4 more. 1 for the aux air regulator, 1 for the cold start valve, 1 for the thermotime switch, and one for the temp sensor. There is also a quick release 3 wire connector from one of the euro cars (I forget which I got it from) that can be used of the throttle postion switch. Link to comment https://www.classiczcars.com/topic/38938-injector-plug-clips/#findComment-349853 Share on other sites More sharing options...
FastWoman Posted March 19, 2011 Share #8 Posted March 19, 2011 If you want brand new, albeit not quick release and not quite as high quality, you can buy them very cheaply off of Ebay. Link to comment https://www.classiczcars.com/topic/38938-injector-plug-clips/#findComment-349857 Share on other sites More sharing options...
tymarbry Posted March 19, 2011 Author Share #9 Posted March 19, 2011 I kind of like the quick release idea but I really just want anything that will hold without the aid of tape. Link to comment https://www.classiczcars.com/topic/38938-injector-plug-clips/#findComment-349873 Share on other sites More sharing options...
sblake01 Posted March 19, 2011 Share #10 Posted March 19, 2011 Brand new really isn't important. It's a trubute to the way Bosch made them (I think it was Bosch), in that the ones I found in the junkyard on BMWs, Volvos, etc. were always in good shape and the ones on the Datsuns were cracked and brittle. Link to comment https://www.classiczcars.com/topic/38938-injector-plug-clips/#findComment-349877 Share on other sites More sharing options...
TomoHawk Posted March 20, 2011 Share #11 Posted March 20, 2011 Yeah, junkyard connectors will clean up really well, just be careful which ones you cut off, and if you get them from the newer cars, they'll be better then the ones Datsun used. IIRC, for the price of one new connector from eBay, you could probably get all you need from the JY. Link to comment https://www.classiczcars.com/topic/38938-injector-plug-clips/#findComment-350090 Share on other sites More sharing options...
sblake01 Posted March 21, 2011 Share #12 Posted March 21, 2011 Are you good with soldering and shrink wrapping? That's the best way to install the 'new' connectors rather than using crimp connectors. When I did mine, the solder and shrink warp was not visible because it was under the rubber boots. Link to comment https://www.classiczcars.com/topic/38938-injector-plug-clips/#findComment-350093 Share on other sites More sharing options...
