Here is the dash of my recently restored car. I installed a modest-priced Dual single CD unit with removable faceplate to get the USB and AUX ports. This is a standard single-DIN unit and it required a very slight relieving of the opening with a Dremel tool to allow the mounting insert to be installed. In addition to the standard switched power wiring, this unit requires a constant-on connection to maintain its memory settings. The nearby clock wire is constant-on and that is what I used.
Hope this helps.
Jim
