Hi, I was wondering what the best option would be? I currenntly have flattop carbs, but I was wondering if it really is worth getting them rebuilt by ztherapy. Otherwise the next cheapest solution is a new pair of weber dgv's, which I heard are not as good as su's, but I have only seen them compared to roundtops. I could get roundtops, but I have not been able to find the full setup, and then I would have to probably get those rebuilt. I have a 1973 240z with and L28, and I am on a very tight budget. Thank you for your help!
https://www.classiczcars.com/topic/39060-flattop-carbs-rebuilt-or-new-dgvs/
I don't think that Ztherapy will rebuild the flat top carburetors. They deal in the round tops, though Bruce could easily correct me on that point.
I have a spare pair of flat tops that I plan on rebuilding. (Thank you 260 Z for your generous gift.) I figured it would be a great way to learn more about them. Rebuild kits are available.
Yoshi,
You will get a variety of opinions.
There are a couple of options:
1. Learn to maintain the flattops. It can be done. Search HybridZ and zcar.com for TonyD. He has written about maintaining the Flattops and at one time had or has a standing offer to buy them. There is also a manual for the flattops.
2. If you can afford the Ztherapy Carbs I think that would be the general consensus.
3 Get a used set of the early SU's. Keep checking Ebay, the classified sections, post a parts wanted ad. Something will usually show up.
Since I have no experience with Webers I can't help you.
Dave Ruiz
:beer:
We are here to assist you in any way we can. For the flattop[ conversion we actually eat a third of the core charge. AND they are a bolt on. An early style aircleaner will be a bolt on as well as the flattop aircleaner has a different shaped opening to the carbs. Check out part number ZT161 or 162 depending how far into it you want to go......
I have the kits, but I do not have any experience in rebuilding carbs, and I need my car running reliably asap. I would go to roundtops, but I am on a tight budget as a college student. And Bruce, are saying you can rebuild the flattops, even though I know they are not the best, or are you saying do the roundtop conversion? Thanks! Also, I am assuming new dgv's then are not the best option?
I don't know of ANY commercial rebuilding service for flattops.
New DGVs are an option, but I don't see much (if any) advantage to those over properly rebuilt roundtops. Plus, new DGVs aren't cheap. If your budget will cover new DGVs, you should also be able to swing a fresh set of roundtops (ZT161) at $730 (includes core).
Edited by Arne
These guys would probably rebuild them for you.
http://www.paltech1.com/id2.html
Not sure it's worth it and I have no idea what quality their work is.
I got rid of my flat tops in the mid 80's... replaced them with webers... Then I replaced the webers with round tops in the late 90's. Now I'm happy
  • Who's Online   2 Members, 0 Anonymous, 1,511 Guests (See full list)
