One of our main concern when we bought the car...The Battery Holder!
Here are some of our working progress on the holder.
-We mark around the rust spot so we can made a precise cut and measurement.
-Cutting out the rust one wasn't as much pain as cutting out the donor car
-After debating if we should use our welding skill or not LOL. My friend came up with a brilliant idea...rivet the battery holder!
-After cutting I than compare both...wow what a different!
-We than rivet the holder into place with million of rivets hahaha just to be safe
-Put Por 15 over the holder just in case it rust again...and yes this time i bought the acid catcher/holder
Edited by upbeatppl
As a general rule, I'd say that for a unibody car welding is a much stronger solution than riveting. You can still lap weld around perimeter of the patch piece. It will also look better when you are finished if you weld and grind rather than having rivets everywhere.
You definetly need to weld that patch in on both sides, the first pool of water will soak the sandwich area and you will be right back where you started in no time. And find an instructional video for welding, and a real welder. A really worth while investment.
  • Who's Online   0 Members, 0 Anonymous, 1,142 Guests (See full list)
