  • 1 month later...
Bump. Now i've located a coolant (?) leak in the 6th cylinder. Also the gasket is a bit swollen from the rear. That explains why i have to top up the radiator quite often. All hints are more than welcome to ease this task. I need to have this car running in 2 weeks so..
edit. i have no oil on the water and no goo on the oil.
Edited by Reverend
https://www.classiczcars.com/topic/39146-new-head-gasket/#findComment-356686
Pull plugs and show us a photo of them.
Tips for removing head:
Secure timing chain tensioner
Put motor at "top dead centre"
Remove 2 small bolts at front of head underneath first
Use block of wood and hammer blows if head is stuck
Clean all headbolt holes
Buy headgasket that matches block
If you have an oil bar, remove and flush it out by spraying carb cleaner through holes
When reseating head, make sure cam is at tdc
Check head for cracks http://atlanticz.ca/zclub/techtips/head/crackedhead/index.htm
Check head for flatness
spray foam (shaving cream or similar) in cylinders when cleaning block surface then vacuum it out with the trapped debris
https://www.classiczcars.com/topic/39146-new-head-gasket/#findComment-356690
Plugs looked brown reddish. There was some oil or something black on the 3rd and 4rd plug, i removed the substance and put the plugs back. Drove about 200 miles after that and plugs are clean. Sheehs, i better found out some who has done this before to help me.. Too many variables to remember.
https://www.classiczcars.com/topic/39146-new-head-gasket/#findComment-356694
R&R-ing the head is not a big deal, but you will need a few tools. I'm guessing you have the stock carbs and exhaust manifold which will keep it straight forward. The biggest worry getting the exhaust downpipe-to-manifold nuts off without breaking a stud. Soak the nuts and studs for several days in a good penetrating oil before removing them. Otherwise it really isn't hard.
Cut a piece of wood to match the timing chain wedge tool shown in the FSM (download from http://xenons30.com). Drill a hole through the top of the wood block and tie a string to it for easy extraction. You will also need a 1/2" drive torque wrench that goes to 150 newton-meters and a 1/2" drive 10mm allen socket. Otherwise, you will need standard hand tools including a 1/2" drive socket set up to 19mm with extensions and a universal joint for the exhaust connection.
With the right tools and some good luck with the exhaust, a novice can do the job in a weekend not counting a trip to an automotive machine shop to measure the head. A skilled Z mechanic can do a head gasket swap on a '72 240Z in 3-4 hours.
If you choose to do it yourself, I will be more than happy to do a complete write-up for you.
https://www.classiczcars.com/topic/39146-new-head-gasket/#findComment-356701
  • Who's Online   1 Member, 0 Anonymous, 793 Guests (See full list)
