Feel like I'm beating a dead horse here, but WTF, whats the worst thing that could happen.
Question, why would you run the ground cable to the furthest point on the block from the starter?
I looked at my 73 last night, the ground cable is like 18" long and goes directly to the block at the starter bolts.
Try this, take a jumper cable and go battery ground post to the starter housing.
Looking at the new pics I see you have a bracket under the lug, I still say you have a ground issue.
I replaced the positive cable, and the battery post clamp on the negative cable. I'll just move where the negative cable goes. I'll try the wire test hopefully today or tomorrow. 5thhorsemann, you mentioned a body ground strap? I was wondering if this is attached to the negative cable, if it attaches separately, and where on the body do you connect it? Thanks!
