totally disgusted w/Z
ugggggh!!!! i was messing with the Z now i have a problem. i put my 5 speed i had from my 72 its a 79 ZX 5 speed. anywho i hook it all up everything goes in fine and well till.................
i go to replace the center panel and the shifter is right at the top of the cut out area for the gear shift.
wtf gives???
i didnt have this prob with my 72. how can i get this to work with out leaving my center console off and having to cut a larger hole in my car.
its on the lift as we speak, and i have to have it out of the garage tonight!!
BTW mine is a 71 240Z build date 5/71
https://www.classiczcars.com/topic/3928-totally-disgusted-wz/
Yup, you gotta do a wee bit of trimming. Your 71 came with the early A model trans with the "monkey-motion" shifter linkage. The 72's and later came with the better B model transmission with the shifter mounted on the case itself. The A model shifter sat further back than the B models.
i went back down to the garage. looked at the shifter and what i had to work with.
then i saw TORCHES buwahahaha
i placed the shifter into the vice and heated that sum bitch till it bent at a 90 degree angle, then about 3 inches back i did it again at about a 75 degree angle.
put the shifter in and voila!!! YAYYYYY it works perfectly=))
thanks for all the suggestions just the same. i think what i needed was a minute to think instead of going insane LOL
but now its working beautifully=))
i :love: my Z again
  • Who's Online   2 Members, 0 Anonymous, 1,453 Guests (See full list)
