Are your wheels hopping, or is your clutch chattering? A chattering clutch is sometimes caused by contamination (oil) or by too much clutch material burnt off onto the flywheel and unevenly distributed, often caused by excessive and hard clutch usage (and a hot clutch).
Wheels hopping at takeoff can be caused by REALLY BAD struts. Wheels hopping at speed can be caused by very badly balanced tires/wheels and bad struts.
How do you know your wheels are hopping? Has someone observed them hopping from outside the car while you take off? Or do you simply feel a bump-bump-bump-bump as you let out the clutch?
Edited by FastWoman
Then your clutch is chattering -- 95% certain, from what you've described. If so, it's probably because you've overheated it repeatedly with too much clutch action, but it could also be because of oil leakage onto the clutch lining. If it's the latter, you need to fix the oil leak. If it's the former, you can find procedures for redistributing the glaze on your flywheel to smooth out the clutch. I've never tried any of them and don't know if they work.
Racing clutches can stand up to harder use, if that's the problem.
Without your sharing more information, all I can really do is to guess what's going on. Good luck figuring out the issue.
  • Who's Online   2 Members, 0 Anonymous, 1,157 Guests (See full list)
