The L-20A came with the 38mm carbs where the 240Z came with 46mm carbs. By stepping up to the 46mm carbs popular opinion would suggest you'd lose bottom end torque.
As far as triples are concerned, I think it would be very easy to over-do things on that engine.
https://www.classiczcars.com/topic/39597-s-u-carbs/#findComment-356028
  • Who's Online   1 Member, 0 Anonymous, 1,532 Guests (See full list)
